ironviper
i just checked my offset on my attak and it was at 20 mm, isnt it supposed to 15 mm assuming i measured right.. i measured from the back of the secondary to the back of the primary with a strait edge.. the seconday has 4 washers on it, 1 thick and 1 thin on the shaft before the secondary and the 1 thick and 1 thin after the secondary goes on, now if i need to be at 15mm can i take the first fat washer off and put it on the outside of the secondary and that will get me close to 15mm. thanks
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Spec is 13.5mm to 16.5mm with 1-2mm freeplay.
Inner spacers have larger I.D. than outer spacers and can not be exchanged.
