04mx
- Oct 20, 2015
- canada
- Yamaha
Long story short , 2010 nytro my motor decided to puke the valves and a rod out the block ...... got a used motor and had the valves adjusted ,put it in and starts fine cold but if I shut it off after a ride or to get gas then when I try to start it again it runs real ruff . The thing is it didn't do that before I swapped the engine . I think the engine is a 2008 or 2009 tho.
Anyone have this problem ? Or had this problem ?
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Any codes?
04mx
- Oct 20, 2015
- canada
- Yamaha
No , no codes but it I give it just a little throttle it starts right up .
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Are you sure the throttle free play is adjusted properly? You might want to run the diagnostics and check the throttle position sensor adjustment on the throttle body.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
bought my 09 xtx new. now has over 22000 on it. has done that last few years. slight crack of the throttle and it fires instantly. I plan to check and shim valve lash and maybe do a tensioner this summer. if they aren't a problem I plan to turn the idle stop up on the rack and assume the idle bypass will compensate. bought a winder xtx this year, but still love the nytro. In many ways I prefer it and my wife rides the winder instead of the apex
04mx
- Oct 20, 2015
- canada
- Yamaha
Il Check again but if I remember it was 16 with the throttle at rest and 95 full throttle .
Idle is about 1400 Rpm I also love the nytro , was thinking of trying a viper ,the sidewinders are out of my price range for the riding time I do , about 1000 2000 km per year .
4strokes
- Mar 13, 2018
- charlemont ma
even if you raise the idle stop, I believe the air bypass will compensate. did this on my apex when new because the butterflies were hanging up a bit from being so closed and tried to kill me a few times trying to ease over obsticles. of course even tough it had 5 year yes, the dealer "never heard of it"... cant always follow the book. randomly came up with the idea. idle remained the same as the computer compensated the bypass. worked good, that was 13000 miles ago.
Not uncommon for older sleds to need some throttle. remember the 583s and 670s with rotary valve. required 3 hands to start
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Which throttle body did you use?
