VECTOR100
i ahve a 05 and i have thew snoetrackers and have no intention on changing them. how should my suspension be set up ? i weigh 210 wiht all my gear and a rough ride doesnt bother me.How shouklf my transfer rod be ste aswell as my limiter strap? any imput would be very helpful to me thamnx
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Try tightening your limiter strap..
VECTOR100
THANX FOR THE REPLY! I WILL TRY THAT
N'orEaster
One Hole up worked wonders for me...+ the addition of some dually bars
twomorestrokes
some more information on your problem may be helpful. What is the cornering problem? Does it "push" or is it ski lift or something else?
VECTOR100
IT WANTS TO PUSH INT HE CORNERS , that was when i didnt have studs. now i installed studs this week so it might push more!
twomorestrokes
With your ride height set correctly, a good transfer rod gap should be about 17mm. Tightening the straps another hole will put more pressure on the skis and may help your problem. I have my straps in the stock position as I don't like a lot of ski pressure. I prefer more carbide. I learned to deal with ski lift and I don't have a push issue.
