How can I tell if a Viper ever had a turbo?
WillowAce
Age
52
Northern Wisconsin
2016 Viper L-TX-DX - Sold
2019 Switchback XCR - Sold
2015 Viper L-TX-LE
2019 Renegade 850 - In the shed just in case
2020 Viper L-TX-SE
Is there a tell tale way to tell if a Viper ever had a turbo?
Trading yours in?
Lol, no maybe the opposite. As hard as I try I can't walk away from the Viper. Fund a really good deal on an LTX, almost too good so looking the gift horse over good.
If it had an mpi turbo, than there would be a small aluminum angle tab riveted to the top of the clutch guard where the oil separator was relocated, also underside of the hood should have two holes cut out for the corners of the intake plenum, unless someone went the extra mile which i doubt it.
If it was mcx turbo on it you can check where the oil sensors are. Mcx take the oil pressure from there and one place there you need to grind/saw a bit of aluminium to fit the oilpreassure to the turbo there
