You need to remove the black housing that goes around the tail light, once that is done there are two nuts that you remove that are attached to J hooks which pull tension on the seat, after that the seat should just slide backwards and out.
Yes as he said but first remove the exhaust end caps only
the 2 allen screws with the blue marks on them. Then you'll
see the 2 "J" hooks that keep the seat tight. Slide the seat
gently backwards and upward on the tail about 3"-4" and
unplug your tail light.
