Hello, first attempt to remove a skid on any sled. Are there any links on how to do this? 2005 Yamaha RS Vector ER.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
APEX 06
- Apr 30, 2009
- Sheboygan, WI
I have the Pro Active suspension. Removal is the same as the mono?
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Proactive skid removal is a snap! Lift rear end of sled, remove 2 rear skid bolts, remove 2 front skid bolts, wrestle skid from out of track, it's that easy! If you want to make it even easier you can remove your 2 idler wheels and mount to the torsion springs but make sure you adjust then to soft before removing the idlers and mount!
RSVECTORFREAK said:Proactive skid removal is a snap! Lift rear end of sled, remove 2 rear skid bolts, remove 2 front skid bolts, wrestle skid from out of track, it's that easy! If you want to make it even easier you can remove your 2 idler wheels and mount to the torsion springs but make sure you adjust then to soft before removing the idlers and mount!
Thank you! That is what I figured by looking at it. Just wanted to make sure!
