2005 RS VECTOR HIGHBEAM ADJUSTMENT?
CENA
WISCONSIN
Hello, need info on adjusting the high beam on my 2005 RS Vector. The high beam shines up in the trees when using the fun flap! Any info much appreciated!
Here are the details as in the owners manual which can be found here:
http://www.yamaha-motor.com/sport/servi ... x?ls=sport
BTW, when adjusting make sure you check you alignment with you sitting on the sled.
This adjustment will adjust both high and lowbeams. I find that I just adjust my highbeam where I want it, then deal with the low beam pointing down too far. If you want to split the beams a bit more....search and do some reading, I have not done the shimming bulb mod yet so I can't help there.
