snoman
are the carbs easy to work on ? or is it fussy to clean them up.
jwifferdill
Apex carbuerators????
YamaMikeRTX
fuel injected not carbed
welterracer
The apex has fuel injection which is maintanance free..
You could SOME DAY have to clean the throttle bodies (remove the carbon) but other than that.. they shouldnt need touching
maxdlx
Run a can of sea foam through it and be done. Simple as pie. Maxdlx
Aaron Eh
You guys don't clean your Apex carbs when you re-torque your power bands? I find it's the perfect time.
maxdlx
As long as you have the carbs off, you may as well change the power steering fluid, and fill the washer fluid, as they are under there somewhere too. LOL Maxdlx
terret725
dont forget to rotate ur gas cap and check your head light fluid
SLEDSTART
You guys are bad...LOLOLOLOL
Re torque the power bands...ha ha
But seriously...the MOST important thing on the Apex would be the fuel injected lug nuts. Gotta keep an eye on those....
whitedust1
Hard to get at carbs tight in there behind the corella bar.
schmeg
my floatbowls remain spotless. no need to clean. I do clean up the points and condenser annually.
Bullitt GT 07
I put my carbs out under the front bumper, keeps them cool and gives me more horsepower!!!
CaptCaper
- Jan 1, 2007
- Northern N.H.
I'm on a 'No Carb" diet.
How much voltage are you guys running at the flux capacitor?
apltx08
Everybody forgets to adjust the d@amn CHOKE cable!!! its very important for a good start at -35deg mornings...
