johnketch
how many should i use for a stock 06 Apex?
and what length?
thanks
and what length?
thanks
JROCK
- Oct 25, 2007
- Ottawa, Ontario
- 2006 Yamaha Apex GT
1.325-1.450 is what most run for 1.25 track. 144 is usually plenty for trail riding.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
144 of 1.325
johnketch
sounds good, now i just have to go buy some.
Nick1945
johnketch
advantage to using double backers?
ShootToThrill
johnketch said:advantage to using double backers?
The studs are held more rigid, less pull outs. Maybe a tad lighter too. Seems to be a more durable setup is what I found.
johnketch
souds like the way i will go
still debating how long of studs
leaning tward 1.450 stud boy stainless
SharkAttak
better hook up with the 1.450
johnketch said:souds like the way i will go
Stud Boy doesn't make the stainless in that length, you have to go with the non-stainless powerpoints.
johnketch
does someone make 1.450 in stainless steel?
Nick1945
johnketch said:does someone make 1.450 in stainless steel?
Woody's , Extreme Max, Shade Tree has there Riders Choice brand also.
- Nov 23, 2003
The Woodys S.S. 1.450 stud are $1.15 W/Big Alum Nut 1/2", backer are .40 Ea.
Bruce
Bruce
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
I had the woodys SS 1.450 in my 08 till I stretched it out last month. They hooked up great. I did see a couple of spots on the front cooler where a stud hit it. After seeing that I would not go with the 1.450 again. Too close for comfort for me.
johnketch
how about double backers?2000srx said:The Woodys S.S. 1.450 stud are $1.15 W/Big Alum Nut 1/2", backer are .40 Ea.
Bruce
