switchback1080
I currently have mcx rear mount 19t kit W/ Head Shim. Stock internals. Was curious if its safe to turn the boost up to 15-18psi and run race fuel only.
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
I am only a customer so i can only speak for my sled and all i know that runs Apex MCX.
It seems that up to 350hp you have a very reliable engine with stock internals and with headchim, that means you can run 20-21lbs of boost if you burn racefuel, or atleast 106 octane.
This is my guideline after have read almost all posts on several forums the last couple of years (4 stroke boosted era).
An engine failure can happen anyway, even @ much lower boost, and then it's quite often an rod bearing that seize.
switchback1080
anyone else.... there is some ice racing this weekend and I want to make sure if I turn it up Things will survive
switchback1080 said:anyone else.... there is some ice racing this weekend and I want to make sure if I turn it up Things will survive![]()
What does 'race fuel' mean to you?
wantboost
i like to run as much as possible untill something breaks and then back off just a tad.seems like the rods are failing before anything.some are running 20 plus,some are having issues at 16.i'll try 18 this weekend with stock motor and c16 fuel.
switchback1080
well im unsure if i need to send out my mcx fuel controler to be remapped for a race gas/increase in boost.... So i wanted to ask here if anyone would had any advice.
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
Like Lakercr said What's Race Fuel? Come on guys there must be hundreds of different fuels out there. Be specific. C16 is good for 20lbs with a headshim, but that's not my choice for a cold weather fuel. Can't say what fuel is best, need all the info for a given setup. 350 HP for stock rods is PUSHING for sure. I DON'T run it till it breaks and then back off!!!
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Sunoco...
