T-Bone
How much horsepower is enough in a new sled? How much is enough and how much you would like are two different things. Generating horsepower cost money. Higher HP sleds cost more to insure. Dealers have told me it's harder to sell a used higher HP sled. Consider these factors and other you think of when voting.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
You need a 'less than 100hp' option.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Personally I don't see a need to go any higher then they are now! A stock sidewinder will go 120mph. There are not many trails where you can even get going that fast so no need to go higher.
But lots of lakes and rivers! Turbo is a compromise. Too much to trust myself with and too easy to get power with.Personally I don't see a need to go any higher then they are now! A stock sidewinder will go 120mph. There are not many trails where you can even get going that fast so no need to go higher.
Well after owning 2 that are over 265 hp I feel that there is never enough. Speed is not a direct result of hp. Speed is a result of gearing but having enough power to drive 700+ lbs of man and machine out of I tight Conner to lift the nose at a plowed drive approach, or a flick of the thumb to sweep the studded track through the Apex of a turn is a direct result of horse power and once you feel it you are never happy with a lesser class motor.
That’s why it shouldn’t be so easy.Well after owning 2 that are over 265 hp I feel that there is never enough. Speed is not a direct result of hp. Speed is a result of gearing but having enough power to drive 700+ lbs of man and machine out of I tight Conner to lift the nose at a plowed drive approach, or a flick of the thumb to sweep the studded track through the Apex of a turn is a direct result of horse power and once you feel it you are never happy with a lesser class motor.
Come on where is your sense of adventure?That’s why it shouldn’t be so easy.
You and Ulmer earned every bit of hp Yamadog. But now just look how easy it is with a Winder.Come on where is your sense of adventure?
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Depends on how much the sled weighs. 150hp in a 400lb is alot different than 150hp in a 600+lb sled.
True but 150hp even in a 400lb sled will not give you a true 100mph if there is any amount of loose or wet snow.Depends on how much the sled weighs. 150hp in a 400lb is alot different than 150hp in a 600+lb sled.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Depends on how much experience and how comfortable the driver is on the sled.
Can't really pick just one.
Yup and a guys mood! Perfectly happy on 85hp Phazer most times.Depends on how much experience and how comfortable the driver is on the sled.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Riding a 40hp Rupp is better than going to work. Lol
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
I remember those days!!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I thought and felt that 135 was enough before I signed on this site, can't get enough now
