How much weight are you running at 7 psi I need more!!!
TurboJamie
Elk Lake
Running a YPY in the primary and 74.5g of weight and hitting 10800+ on 7psi on the apex = about 9-10 psi of boost I have to get it down a bit. How are you guys getting more tip weight? That is the rivets a got from the dealer are heavier available? BTW this thing is just about as stupid as you can get I don't even know why anyone really needs more then 7psi of boost on a sled at all. At least not for flat land trail riding. Im banging the speedo off 140 steady on the lake as well racing other sleds nothing has even come close!
What holes are you in on your secondary. I am running 10 lbs of boost on mine and I have 87 grams of weight so far and will be adding 2 more grams on monday. I have Super Tip weights and they are awsome to work with. Boost is fun isnt it.
Sorry my math was wrong I have 81 grams in right now and will be going up to 83 grams Monday.
Im running the stock cluch at 50* of wind and I also have a team roller that I just put on tonight to try.
What spring do you recommend? Im kinda useless at clutching this thing after coming from doo none of it really makes sense yet :drink: Right now I have a Yellow Pink Yellow in it and the big weight and the hartman helix in the seconday at 50* wind and a black silverl black in it.
