ualav8
This is my first year prepping any sleds with the exup system. (13 apex and 12 xtx)
How often do these valves need to be adjusted? Annually? Every couple years? Never?
I've seen the video on how to do it. Just wondering what to expect.
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Annually for sure...
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Definitely annually, and I am on my third set of cables on my '13 XTX. Noticed a loss in top end, and mileage= broken cable.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Checked mine last winter on my 11 and it was fine cable where good so in 8,000 miles no adjustments and no broken cables.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I think that is rare I had broken cable last year on mine.Checked mine last winter on my 11 and it was fine cable where good so in 8,000 miles no adjustments and no broken cables.
icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
I had broken cable at 5500 miles need to check annually. I think it has to do with if you ride on any salted roads mine were rusty. Wish they were made out of stainless cable, I think they would last longer.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Not on bit of rust on my cables or any other part of it but it only takes a few bolts to check it. Stainless is always nice.
Seems to be a lot of variation on this subject. My 2012 XTX has about 5500 miles. I've checked the adjustment 3 times and it has always been very close. Cables are in great shape still. Dad has a 2011 XTX, same story. Seems like there has to be something different in riding conditions/storage/trailering causing some to have rusted/broken cables so quickly, and others going multiple seasons without even needing to adjust.
- Jun 28, 2004
- Clinton, Wi.
2 sets of cables on mine, and would have been a 3rd if I could have found a set. I rode all of last season with mine disconnected and saw no difference in power, mpg, or mph. I tied mine in the full open position and left it.
molicious
- Sep 23, 2010
- Barrie Ont
- 2011 Apex xtx
2010 Vector xtx
i was thinking the same thing and heard the same thing. I guy I know just every apex he owned he removes it altogether and fabs up a plate..swears by it. I may try it.
10000 kms on my apex never even looked at the cables
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
ualav8
So as it turns out, I had a b!tch of a time getting the 2 5mm Allen head bolts off the valve. Had to tortch the fwd bolt off, and in the end, the head snapped off anyway. The rear bolt wouldn't budge and I rounded it out. I was able to move the cover enough to see that the top cable was broken. So it's off to Pats Yamaha to take advantage of the YES warranty!
streetfighter
- May 2, 2005
I had same trouble with mine one broken cable had to cut bolts off I just tied mine wide open works just as well.So as it turns out, I had a b!tch of a time getting the 2 5mm Allen head bolts off the valve. Had to tortch the fwd bolt off, and in the end, the head snapped off anyway. The rear bolt wouldn't budge and I rounded it out. I was able to move the cover enough to see that the top cable was broken. So it's off to Pats Yamaha to take advantage of the YES warranty!
yamahahaapex
If the exup fails in my 11 apex it will ge the same treatment as my roadliner with exup. Cables removed, valve tied WFO.
ranger1
Is there any aftermarket stainless cables available yet or would coating them with never seize, grease, Wd40 or something help them last?
