How to adjust weight transfer
dylanjen9
Florence WI
Have a 2007 apex mountain. What do i have to do to make it transfer more weight to the track? I know it it something with the rods and nuts on back of skid but cant figure it out. Already let limiter straps all the way out
bigger gap more transfer. Let out the limiter and tighten the center spring.
This is what it looks like what do I do to adjust for more transfer
Looks like the gap is maxxed on the back, I would make sure that limiter is out all the way and add some spring tension to that front shock.. also make sure the rear spring block are on S for soft. If that dont let the front end come up then you are blowing at the track and not getting traction...
Still can’t get any transfer the only thing that isn’t stock is I have timbersled drop brackets. Could they be the cause? My gearing is 19/40 is that to low and blowing out track? Should I look at something that is stuck on suspension?
