Has anybody posted a video of how to change the bearing on the main driveshaft opposite side of chain case. I would like to know if there's any shortcuts that can be taken. Thank you very much.
Remove the secondary to access the speedo gear,
Remove the speedo gear,sensor and gear cover.
From under the tunnel back off the set screws on the bearing.
With a pry bar tap out the bearing.
You may need to back off the track tension to give you some wiggle room.
