the dealer told my dad how to do it and it was way easier and was really easy when we did it. to drain the engine oil you just go from the bottom of the sled, you will see a plastic cover(remove it) then you see the filter and the engine oil drain plug, drain both of those, then take off the right side body panel thing and drain that oil. you be able to do an oil change like that in about 30min.
