how to check oil on apex
slow x 2
ontario canada
hey guys love this site!! As i am on here all the time now.Anyways i just picked up a 2006 apex rtx with 2000 miles on in and i have checked it over many times but i still have no idea how to check the oil in it,no idea where the dip stick is,is there even is one so i hope one of you guys on here can tell me where to look thanks.
Welcome to the site. You will finds lots of useful info here. The dipstick to check your oil is located on the top of the oil tank. The oil tank is on the right side in the under hood location. You will have to remove the hood and the right side panel to access the oil tank. Once you remove the right side panel, you will see the oil tank towards the front (large gray/silver metal tank). The dipstick has a plug on the top of it, which you will have to unplug, then unscrew (counter-clockwise) the dipstick to remove. The measurements are right on the dipstick, which you will see once it is out of the oil tank. To check the oil level, do not screw the dipstick back in. Just stick it in the tank so it is seated flatly, but not screwed in. Hope that helps and good luck!
--Steve (O.C.)
Thanks for the quick reply.I have found the oil tank didnt know that the dipstick was the one with the plug on it thanks a bunch.
oil
also make sure your sled is on the ground not on lift, and you can run oil just a tad below the full mark.
slow x 2, welcome to the site and the world of 4-strokes.
Regarding your question, it many other questions you might have are listed in the Apex FAQ at the top of this forum. You can also click on the link my signature. Please see this thread as there are often step-by-step instructions with pictures for most maintenance activities. ;)!
oil
it depends on style of lift but your sled sets at a different level on the lift.
oil
I think the snow machine has to run for s few minutes to circulate the oil and warm up first also. I think I read this in the manual.
