JERSEYJOE
MY APEX HAS A FLASHING 84 CODE WHICH IS THE tor SYSTEM HOW DO I FIX IT?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Check throttle cable free play.
JERSEYJOE
FREE PLAY IS FINE
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Did you add a riser
JERSEYJOE
no did nothing from last year.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Unhook the cable from the throttle block and see if you get the code
and quit yelling... that cable is to tight.
snowbiscuit
If nothing has changed since last year, there is a good chance that throttle bodies need lubing so that they close freely when letting off throttle....have seen this on friends sled
JERSEYJOE
WE did change the throttle block. the information was spot on. all we did was loosen the throttle cable about 3 turns and it is fixed. thanks all
I was not yelling. I am visually impaired and sometimes CAPS make it easier to see.
Its ok Joe... we are just messing with you
Renaud
- Dec 3, 2024
- Gaspé
- Apex 2009 gt lt-x
Mycable is ok i have a 0.4cm play with blockCheck throttle cable free play.
And my trottle cam is flush on the idle screww
And i have a code 84 and code 15..
Do you have idea?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
You’ve got a TORS code and a throttle position code, I’d start by inspecting the wires inside the rubber “boot” under the hood. Mice love to snack on stuff like that in the off-season.Mycable is ok i have a 0.4cm play with block
Do you have idea?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Exactly, if we really wanted to pick on you, we would make a generalization that all east coast folk are loud and boisterous. Which your profile does not confirm..... mmm... oops. May want to edit the "all caps" We may mistake you for one of the loud guys on the Sopranos.Its ok Joe... we are just messing with you![]()
Glad you got your TORS issue figured out in the shop though. It's a safety feature for a reason.
RobX-1
- Coldwater, OH
Sorry bif but having a chuckle at your expense as always lol when someone resurrects an old post to comment about having a similar issue and waiting to see someone else post a comment as if it was a current post.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Holy crap, no doubt. Didn't even look at the dates. Holy thread resurection!Sorry bif but having a chuckle at your expense as always lol when someone resurrects an old post to comment about having a similar issue and waiting to see someone else post a comment as if it was a current post.![]()
