How to get rid of that Clutch/ Brake dust???
mx1500
meath park, sk, canada
the clutch side is full of that belt dust, its grey and is a pain to get off ur hands and sled parts. then even the other side where the brake disc is? how do you guys clean that sheet off? :o|
i sprayed some brake cleaner on a rag and wiped it clean. really breaks it up. Just a lightly damp rag with brake cleaner will work...
Power washer
I use this stuff called purple power i get it from carquest or walmart spray it on let it set for 5 to 10 min then power wash off......works great
I wonder if there is a aftermarket brake pad out their somewhere that won't make that mess. I can clean that off every ride. Get in some good powder and it is running down the sides of the panels. I don't even have to use my brakes on some rides and that crap is all over everything still.
mike3577 said:
Power washer
at the end of the year i pressure wash mine. hot water and soap works great. don't get to close then park sled in heated shop to dry out
