Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I noticed a bolt hanging out back behind the steel mesh under the tail light on my Warrior. How do you gain acsess to the muffler and also how do you remove the seat? It looks like some rivets have to be drilled out.
Thanks in advance
Thanks in advance
Grunter
- Jan 24, 2006
- Northern Ontario
- ZR9000
seat removal
remove two top hex screws on exhaust caps - then bottom one.
remove two phillips head screws on light bezel
remove the two bolt which fasten the seat down
lift seat, unplug harness and remove.
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
Bob, it's so easy it's not funny. Once you start removing bolts you will see that it just comes right off. Surprising how little holds it on there.
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks you all
So those rivets on the back by the tailight need not be removed?
QCRider
- Feb 27, 2004
- www.myspace.com
Nope.
Bob Miller
- Apr 19, 2003
- New Milford CT
Will the muffler then be exposed?
QCRider
- Feb 27, 2004
- www.myspace.com
Yes.
Red2003
The muffler wont be exposed, but the exhaust shield covering it will be.
Turbo50Mike
QCRider said:Surprising how little holds it on there.
For most of us, our fat asses do a good job of holding it on there.
RX1Jim
Yeah you're right Mike. A couple of people on this site were talking about how fat your #*$&@ is and how bad they feel for you seat and suspension! Just kidding. 8) 8) 8)
