How to remove shock from apex gt
shock
unbolt transfer rod on one end. take rear suspension bolts out, it will be easier. follow the wire and unplug behind right side panel, don't for get to cut the zip ties. unbolt shock. if you are only changing the spring the shock does not have to be removed.
You say take rear suspension bolts out, you mean the transfer rod bolt or the bolts going thru side of tunnel into suspension?
