Hyfax extender wheel spacer kit from pioneerperformance
sniperviper
Norway
Hi. Just wondering if any of you have tryed this spacer kit, and if it made any differance on the hyfax/slides wear?
Are about to prepare my 06 apex rtx for the comming winter (no snow yet :o| ) and came over this kit on http://www.pioneerperformance.net/
I do not like the idea of bigger wheels or drop down kits. If you picture riding down the trail. The snow will push the track up to the sliders any spots that do not have wheels. So the bigger the wheels the more of a wavy path the track has to take as it spins around. I added a set of wheels to the bend in the rail and am running hyperfax this year. I found them for $150.
pioneer hyfax saver kit
I have had good luck with this kit and the new blocks that hold the wheels to the slide rails are much beefier to.
Re: pioneer hyfax saver kit
new blocks they supply?
I put them on both of my sleds, plus the extra wheel kit at the bend. I use the stock hyfax and been having good luck. They supply the blocks and hardware. Is what is nice with his kits, if you ever have a problem with a wheel you don't have to remember all these extra part numbers. He uses the stock Apex wheels.
Got a set so I'l try it.
so based on that picture..the washer would not be centered against the bearing and the bearing wouldnt have equal pressure?
Right. But the washer is not that far off center but still hits all the way around on the race. Also is what helps the beaing is the very tight fit on the block, only a couple of thousandts slip fit. I own a machine shop and I was going to make some but but the price it wasn't worth it to me, i would have to do a run of 50-100. These were machine good, the only thing I did to them was hard anodize them so they wouldn't corrode.
I had to "customize" them for the aftermarket blue yamaha idlers but very good quality product.
what if I wanted to add an extra set of wheels in the skid? guess I'd have to get another couple blocks>?
I changed out my front wheels to Slydog wheels they are slightly larger at 5.350 diameter..
I lost no speed and trippled my hyfax life and evened out the wear..
