hyfax wear on attaks
Does it have to be on the jackstand or on the ground when you do this, or doesn't it matter? THAT sounds like a really cool trick!!! ;)!
hemiram said:
i get 800-1200 miles out of a set. have the slide sticking out of the window put the sled in reverse and give it some gas and the track will peal the slide off
you have the track off the ground. i hang the rear of my sled from a 2x4 in the garage and then take a pry-bar to get the slide started in to the track window
I have never changed a hifax before in my life, so this summer I bought one of those hyfax removal tools. It is basically a rod with a big weight on in it that slides back and forth. You screw one end in to the hyfax and then just pound it out. Like I said I never changed hyfax before in my life and I did mine in about 30 minutes the first time, and I should be able to do in about 10 minutes now as long as everything goes to plan. The tool is about 60$ which is somewhat alot to replace a 10$ part, but I have it for the rest of my life and it saves me alot of time, so I highly recommend it.
Put on oversized wheels and most of your hifax wear will be history. Smoked a set in 300 miles first trip in Muni last year. Put oversized wheels on and about 1500 more miles. Not changing them this year.
