GRIZZSTER
- Apr 14, 2018
- 2011 Apex SE
I installed the hygear dual pressure on my fox floats. I took the sled out twice and after sitting for a couple weeks all the air is out of them. I am wondering how anyone might have installed theirs.. Should I use plumbers tape on the threads to make better seal? Before this happened I increased the height pressure from 65 to 70. When I took off the cap I did hear a small shot of air come out.. I don't think that this should happen. Any ideas?
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
They test them by submerging them in water to check for leaks, try spraying some soapy water on them to see where there leaking once pumped up. hope this helps
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
As 20/80 said sub merge in water and you'll see bubbles where its leaking.
GRIZZSTER
- Apr 14, 2018
- 2011 Apex SE
Thank you.. I took them off and back on again.. Pretty sure sled will be flat on the floor again. No leaks before I put them on and now both sides leak.. Seems a bit odd to me that both are doing the same thing.They test them by submerging them in water to check for leaks, try spraying some soapy water on them to see where there leaking once pumped up. hope this helps
GRIZZSTER
- Apr 14, 2018
- 2011 Apex SE
GRIZZSTER
- Apr 14, 2018
- 2011 Apex SE
I just happened to notice this on Hygear. It says up to a couple hundred pumps in the bottoming side of dual pressure. Is this correct? I'm lucky to put 40 pumps in and that brings it up to above 150lbs. Maybe 20 pumps.on ride height.. How many pumps approximately do you guys put in.I installed the hygear dual pressure on my fox floats. I took the sled out twice and after sitting for a couple weeks all the air is out of them. I am wondering how anyone might have installed theirs.. Should I use plumbers tape on the threads to make better seal? Before this happened I increased the height pressure from 65 to 70. When I took off the cap I did hear a small shot of air come out.. I don't think that this should happen. Any ideas?
