TheHooter996
- Jan 1, 2023
- Massachusetts
- 2008 Yamaha Phazer RTX
All, a couple of days ago I picked up a 2008 Yamaha Phazer RTX with 1030miles on the odometer. I checked the sled out pretty well (I thought) took it for a test ride and took it home. Sled is in great shape cosmetically. Got back to the house and when I put it
on the lift I noticed track tension needed to be adjusted by the large gap I could see between the skid rail and track. I rolled the track forward and noticed the gap disappear. WTF? Then I saw this. The upper bogie wheels have a huge flat spot and both are worn exactly the same. Everyone I’ve talked to about this is baffled. Yes the wheels do turn, bearings are not locked up, which doesn’t mean they weren’t before. What are the chances the bearings locked up at the same time? I don’t know what to think of this.
I didn’t notice any thumping on the test ride, as when the wheels are loaded the track rides on the flat spot. Under no load (up on the lift) the wheels do turn as I spin the track by hand.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Ice build up and frozen in place.
YukonMP
- Dec 25, 2014
- Yukon Territory
I go after mine with a rubber mallet in the morning if it was parked outside. The comment above explains it for sure.
Nice sled, you'll enjoy it.
TheHooter996
- Jan 1, 2023
- Massachusetts
That makes sense, thanks! Bogies at Troy City Garage, NY are $72/each. I bought em, but there must be cheaper options out there right? I was apprehensive ordering through Dennis Kirk because I wasn’t sure these were bogie wheels. I checked the schematic through yamaha and they are different part numbers than the bogies at the rear of the skid. Any one have any advice on other options?
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
Both of my 2010 Phazers had that same issue when I bought them. The stock wheels are all plastic and tend to slip inside the track easily if frozen with a little ice. I upgraded them to some Cat wheels part # 3604-264 which have rubber tires on them that seam to eliminate the slipping issue. These are the same diameter and use the same bearing so it's a direct swap. I believe I had to reverse the installed direction of the wheels (snap ring on opposite side) to clear everything but otherwise no issues. Also, drilling a hole in each wheel with a spade bit to allow for easy shock bolt access is necessary.
I bought a used set of four on ebay for $50 with bearings. The bearings in these fit much tighter in the wheels compared to the stock ones. Overall a much better designed wheel than the Yamaha unit.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Yep, those AC wheels are the holy grail of replacement upper wheels for the Phazer. I'd get better quality bearings though.
ty4stroke.com
edit: That thread has a different part # that what @turbogts22 listed. I used 3604-616 and they fit perfectly.
Replacement upper guide wheels
These may be the way to go. The rubber should help prevent flatspotting from Ice. I recommend buying new 6006 bearings (stock Phazer) for them though since ones in there are CHINA and I have seen failures of bearing. Part # and cost TBD but they are off a 2014 AC SnoPro 600. Let us know how they...
ty4stroke.com
