YamahaMarc
How do I access the screws/ bolts for the starter on a 2013 Yamaha vector? I have removed the airbox battery battery holder motor mounts in the front motor bar oil tank oil filter, etc. I see the starter, but I have no idea how to access the screws or bolts.
Thank you so much, I think it might be an over my head.
CaptCaper
- Jan 1, 2007
- Northern N.H.
Lot's of good info here so search until you get some help. I'll attach a file that may show parts. Also I bet on the youtube would have something.How do I access the screws/ bolts for the starter on a 2013 Yamaha vector? I have removed the airbox battery battery holder motor mounts in the front motor bar oil tank oil filter, etc. I see the starter, but I have no idea how to access the screws or bolts.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Remove the secondary clutch, move engine forward.
Remove the rear motor mount bolt along with the exhaust and tilt the motor forward.
Its tight but the starter will come out
