i need help replacing my proaction skid
ualav8
Watersmeet, MI- Da U.P.!
after removing my skid for some re-bushing and bearing maintainence, im trying to put it back in. i got the forward set of bolts in no problem. i loosened the control arm adjusting nuts in an attempt to get the mid bolts set but i needed a ratchet-strap to act as a come-along to get them in position. now the rear bolts are about 1.5 inches off their mark and i cant find a 400 pound gorilla to get this thing in place. im pretty sure this isnt supposed to be this hard so i'm obviously missing a step/trick somewhere. can somebody help me out on this? :o|
remove the bolts from the bottom of the transfer rods.it will go right in.
there is a bolt that goes into the bottom of the transfer rod. It goes upward toward the top.Its a pain but well worth it.
