Janzka
- Sep 15, 2013
- Finland
- Other
- Sr Viper MTX Se 153"
My stock viper mtx take only up to 8000rpm in powder snow(1 meter snow).. Stock secondary preload is 50 and I have now 70 and still under max 8000rpm all the time. What do I do?
My new video. Listen to the sound. Lazy as the Koala
http://youtu.be/c9iV0PQ8Gqg?list=UUiTvUPBJnJDDP1IQVVFa6qQ
viperdudese
- Nov 20, 2014
- Sweden
- Yamaha SR Viper MTX 153
You dont think it get to agressive with a spring with more preload than 50 ??? In the MTX se 153" there is a spring with 45 preload and 111 in totalforce, i think you shall do lika this, i tried it on a stock MTX and it get allot better and smother to drive, put in a spring that is 25 preload and 113 in totalforce. The sled can now work on a wider RPMarea and thanks to the higher totalforce you increase the RPM, and if you still not are satisfied drill out the outer rivet on the weights.
This is a cheap way to go but it increase the performance of the sled ! Hope i helped you a litle.
viperdudese
- Nov 20, 2014
- Sweden
I think here in sweden we have similar nature to drive in like you in Finland so i think this will help you
Janzka
- Sep 15, 2013
- Finland
- Other
Thanks dude.
I believe that will help me
A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Yamaha Viper MTX 162" MCX Turbo 190
- Sundsvall
Remove the top rivet in your primary and go with 70 preload on secondary.
SweViperSe
- Jan 13, 2014
- Sweden
- Sweden
- Yamaha viper mtx 153
How did it work? I got the same problem on my mtx 153.
Janzka
- Sep 15, 2013
- Finland
- Other
My dealer said that don`t remove top rivet in primary.. I still waiting for tips for my dealer.
SweViperSe
- Jan 13, 2014
- Sweden
- Sweden
Hi janzka. How is it going? Find something that works?
I'll tried white secondary spring, din't do anything. Tried to remove 3g on primary, and nothing happens. I'll don't understand this clutch! How big changes do I need to do to get a reaction?
Janzka
- Sep 15, 2013
- Finland
- Other
Hi!Hi janzka. How is it going? Find something that works?
Work little better, but I think that reason why works better is hardened snow. I putted also white spring and maybe work little better.. I also tried 37-47 helix and works less well. Try 8DN-17641-01-00 belt, may work!
stingray719
