i need help with self dio
grumpysanta
hudson quebec canada
I have a code flash on 04 warrior with " dio " flash with gas light and fuel bar flash all at once , 8 short flashes the off the 8 flashes . i have removed fuel sender and looks ok and plug connector looks ok , what else should i check , I need to change the speed sensor because it broke when lower bearing went south. but i do not believe it has any thing to do with fuel guage..
Follow that link and look at the right page item labeled as number 2, it says short circuit.
SORRY but thats for coolent not fuel as i said , my fuel light and fuel graph along with self dio. light all flash at the same time . 8 flashes then off and repeat .. thanks
Try this:
ok i have been there tried that seen that page in manual , what else could it be in the fuel system , sender has been changed twice..
Was the sender within spec? I could be a wire issue or a ground issue. Not sure if the RX is subject to the grounding block issue but it's worth a shot....... http://www.ty4stroke.com/viewtopic.php?t=101648
There are a handful of grounding blocks in the harness, some of them like to get warm and 'melt' a little causing a high resistance/open situation. Could be the ground for your fuel sensor suffers a similar fate. You can check the resistance of the sender from the plug in the back of the dash. This will indicate any bad wiring. Test for resistance from the G/B (green with black tracer)wire at the dash, to a good ground. Anything much higher than the sender spec indicates a wiring/connector issue.
