dirkdiggler
Suspended
Ice Nitrous is anyone using it? If so how many Nozzles does it use. If it's only one where do you install the nozzle?
adirondac blue
Have you got deer hunting on the brain.(doe)
snowy1
I have the ice nitrous on my sled, I have the wet system it has a manifold with two jets one for nitrous and one for fuel, I have it mounted on my charge tube between the turbo and innercooler, works very well easy install and set up. I put it on last year befor I went to fairview did not have time to test it befor I left when I hit the button the first time at fairview it worked perfectly all day never touched anything. just change fuel and nitrous jet sizes for the desired hp. gain.
dirkdiggler
Suspended
dirkdiggler
Suspended
snowy1 said:I have the ice nitrous on my sled, I have the wet system it has a manifold with two jets one for nitrous and one for fuel, I have it mounted on my charge tube between the turbo and innercooler, works very well easy install and set up. I put it on last year befor I went to fairview did not have time to test it befor I left when I hit the button the first time at fairview it worked perfectly all day never touched anything. just change fuel and nitrous jet sizes for the desired hp. gain.
Sounds good
