Ice scratchers
sure....i'll do it tonight....sleds in pieces but you'll get the idea....do you have an XTX or short track? cause I have them mounted on both sleds
h
sorry for the shitty pics.....i have the left on the right side and the right on the left side......you want the finger of the rod close to the track
Does it come with a hook to keep it up under the tunnel? What did you use
yes, comes with everything you need- (might want to switch to longer nuts and bolts for the rear mount- maybe a stronger grade bolt, but that's up to you)
kimpex part# 04-910 ($49 canadian)
go on Kimpex (US site) and you can enter your zip code and it will show you the closet dealer
