Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
So I have an 08 MTX with a stock skid. I converted it to run 2 wheel in the rear for better side hilling. Well when I had my skid out at the end of last year for a look over I notice the bearings were pretty sloppy. Are there different wheels that I can run that are the same size and wont cost me $80 per wheel? Seems a bit much if I cant replace just the bearing.
Dr. FeeLGooD
You can buy jobbers with exchangeable bearings.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
If your wheels are stock size, these Yamaha wheels are a great buy. They are well made and have replaceable bearings. G.B.
http://shop.portyamaha.com/eshopprod_cat_10025-191_product_2328456.Spoked_Rear_Axle_Guide_Wheels.htm
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
I ordered 7" kimpex idlers for mine this fall. They look like the outer rear idler wheels but they work perfectly fine for me in all positions. I put 3 of them in to make a 4th wheel kit on my nytro xtx. They're still going around and around anyways.
Deeppow16
- Oct 19, 2015
Does anyone know the inside dimensions for the bearing(the dimension where the shaft slides through)?
ssrider
- Dec 8, 2012
- Manitoba
- 2009 Nytro RTX
On the weekend I had my axle nut fall off and lost my rear wheel (and just about lost the entire axle before I noticed). I did some research on this site and found that the older SRX/SX use the exact same wheels as the Nytro. Last night I bought a used complete rear axle with wheels and it is a direct bolt on. Also bought 4 of the smaller wheels from the SRX and they are identical as well. And they all have changeable bearings!
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Inside dimension should be 20mm. Bearing is a 6004-2RS or equivalent.
Deeppow16
- Oct 19, 2015
Thanks guys! I found a pair of kimpex wheels on eBay for $50 new!
