whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Had new donuts installed under warranty in Spring 09 on my 07 150 4s Apex Attack GT then stored all season until now. First 2 rides this year both 100 mile rides & got 16+ then 15+ miles per gallon. Last year & year before mired around 12.5 miles per gallon but a few times jumped to 14 miles per gallon. When dealer installed donuts there was a problem with a kinked gas tank vent line that kept ballooning the gas tank until we found the problem. I have been easing into higher speeds & ready for WOT riding now so lighter on throttle but hit triple digits on trail today. Now I'm wondering what caused the improved gas milage? Any ideas? What milage are you getting with Apex GT Attacks or Apex LTXGTs?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
On several Attaks I have always averaged no worse than 17.
how many miles are on it? There was a noticeable difference in rpms on my sled around 2000 miles
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
About 4,800 Miles.
The Artist
I have seen an exhaust leak cause fuel mileage to go down
littleredsled
its not hard to hit triple digits all u have to do is turn it over to kmh hahah thats the way us candians like it ... it makes us seem like were going faster hahah
Pakratattak
Just got my first ride on my '06 Attak, after installing all new donuts and mid-pipes, 90 mile ride, only got 12.4 mpg.
SnowBandit
- Jan 31, 2004
- NH
- www.slednewengland.com
- 2009 Nytro xtx
I get 14 at best on my 06 even with new donuts.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
135 miles on Fri. 13.6 mpg, new doughnuts and S.S. pipes.
It all depends on what you do with your thumb,i have seen good & bad,its all been fun.FITCH FUEL CATALYSTS helped me out little.
apltx08
Avg is 13 to 16 mpg...a lot of factors come in to play, weather the colder it gets the more fuel you use oils and grease are thicker/stiffer, snow conditions fluffy to heavy or marginal amounts will create more friction on track and HYFAX'S needing more power, SPEED its like any other performance engine the more you push that FLIPPER the more you need of the liquid GOLD! but who cares when you compare to a 2 SMOKE avg 10-12mpg if your lucky + OIL at $40-50/gal and DOWNTIME/shorter life of motor. I'm not complaining since I've switched to
