Turbo Tim said:otis said:What is the consensus? Fully clipped or not with extrovert drivers?
Otis
If you use hiperfaxes , fully clipped . If you use stock hyfaxes all windows have to be punched open , but only every 3rd clipped. Hyperfaxes will melt your track ,if not all clipped.![]()
black john said:rx 1 mtn,s came with 8 tooth drvers. std rx 1,s came with 9 tooth and yes you must run a fully cliped track. as well as cut down the drivers.
BRP Extroverts are as follows:
8 tooth #504152552
9 tooth #504152503
10 tooth #504152502
these drivers are appx. $50 US each
I wish I would have installed these instead of the Kinetics I'm running now. The Kinetics are good, but these are better.
You need only two drivers and you will have to press them on/off. Have a shop do that for you, they'll take all the measurements and place them accordingly. They shouldn't charge you more than 1/2 hr labour for that.
