kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Slowly chipping away at the summer projects. I installed my 13MM sway and just rocking on teh sled in the garage I can tell a difference. NICE!
Still need to pull the engine and fix a waterpump leak, new track and jackshaft bearings and some small other stuff and I should be good!
dexter
sounds like you are making great progress.. I have thought about updating the sway bar on my warrior, but I am deep in skid and a arm bushings right now. You mention the jackshaft bearing.. is this the secondary bearing on the clutch side? If so is it just a bearing or some sort of lock bearing?
dexter
Kinger, did I read elsewhere that you have nylatron bushings in your rx1? If so where did you get the bulkhead bushings? I am assuming that I need to change mine if they are updateable.
kinger
- Jan 17, 2005
- Clear Lake, IA
I meant all bearings, expecially the secondary one on the jackshaft, but I'm going to do them all. My sled has about 3300 miles on it and figured it was time while I had the track out.
dexter- I got the bushings from Pioneer Performance a complete set for $60, includes every bushing on the front end except sway bar bushings.
dexter
did you just get the bulkhead ones? Bruce over at Pioneer told me the nylatron b-heads werent ready yet. that would be sweet if they were ready! I am debating as to just put Yami ones in so it is done.
You got pretty good mileage out of those bearings.... I have 7100 miles and need to replace the jackshaft bearing...
kinger
- Jan 17, 2005
- Clear Lake, IA
Actually I haven't installed it all yet but I thought it was both upper and lower bushings. Mmmm lemme check on it.
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
get the oilite bushings from Ullmers, they will out last any stock ones hands down. Maxdlx
