stephenpen
Why do people install them two different ways. In the instructions it reads to put the bulkhead bushing from the outside in. The stock bushings go inside out.
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
What i did was install the front bulkhead bushing first the use the bolt with a washer on the end and pounded in the back bushing. Bolt would keep the bushig pretty square going in and washer saved the flanges. worked out well.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
stephenpen said:We do people install them two different ways. In the instructions it reads to put the bulkhead bushing from the outside in. The stock bushings go inside out.
I contacted Ulmer after I put mine in the same way the factory did, he said he instructs the other way as it is easier but said doing it the stock way doesn't make much of a difference.
If I had of read the instructions, I would have saved myself some grieve!
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I put the bushings in the factory way and had too much slop. Put the engine side bushings in with the flange on the a-arm side and that removed the slop.
I just finished installing the Ulmers kit and like the some of the others I install the upper a-arms from the inside. It just looked to be the right way and I used the bolt/nut method to press them in. Just be careful not to tap themout when re-installing the shaft. They made a huge difference and the front end is tight as a frog's
under water. I did mine the same time I was changing the oil, need to remove basically the same items. Good luck
under water. I did mine the same time I was changing the oil, need to remove basically the same items. Good luckx2 on everything that was said. just put ulmer's kit in on the weekend everything when in great. got a great price at the novi snow show.
yamahaapex07
use a bolt with washers and a nut.
it is super easy to install the bushings in tight spaces with a bolt and washers. when you start tightening up the nut it will align itself perfectly and not damage the flange.
