installing white spring help help
apexgt4life
Rochester, NY
ok how do u install this spring, i put it in and now have a gap between helix and wear pads, seems like i di something wrong. put spring in same hole on helix but what about clutch. i marked all parts with magic marker so they lined up but not looking right. what hole do i use in clutch.
please help
please help
pm turk, he's the clutch guru, he can walk you thru it
You need to position the spring in the correct holes for the desired twist, probably the 6 and the 1 for 70 degrees of twist. Then you have to twist the two halves and then place them together on the three studs. This will force the buttons down on the helix. If you twist the wrong way, you get what you have. First time I had mine apart, ... I had the same opportunity.
set the sheaves together with no spring...put on something to allow the hub on fixed sheave to hang through...the clutch will be closed....set the spring in 3 AND 3 on the helix (60 degrees)... rotate the helix to the right to get the holes to line up with the studs and push on and install nuts..
ok i almost get it. on the outide i put the spring in the 6 hole which my factory spring was in and the position ths othe inside hole were, first clutch experience
Set it at 3 and 3 (60 degrees total) 70 is really tight on the white spring, and if you set it in hole 6 like you have, then hole 1, it will be at 70. Set it in holes #3 on the helix and the clutch.
ok is thier markings on the clutch for 3 i did not notice them and your telling me to move it out of the 6 hole and put it in the 3, now i marke the helix and clutch come together for a reference when puting back together our those marks of no use. thank u very much u guys r great
When changing the helix/spring on the secondary it's alot easier if you do it on the sled, especially if it is up on a lift. Just put the parking brake on to prevent the secondary from turning.
Kaz
There are numbers in the castings that are hard to see if you don't know their there?
Cobalt
:-o
