Ipone oil
DennyTuna
Ohio
25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Just saw a 2 minute clip on snow trax TV regarding this oil. Anybody out there using it? Claims it's made with a product called ester that bonds to cylinder walls better and holds its viscosity ratings vs tradition oils using wax and chemicals that break down, lose viscosity and don't bond. They also claim it improves overall performance and top end speeds of high revving 4 stroke motors. I went to there web site but not much info there that I could find. Interesting oil though.
Can't speak for the 4 stroke oil but I use there 2 stroke oil in my SRX and like how the power valves stay clean.
Same here,i have run it in my 2-smokes and it smells good,strawberry smell,i plan on getting it for wifes 600 poo poo Walmart has it 39.95 a gal.
OP.....Search up the oil thread we had going earlier on. Some good info there on oils and real world wear ratings.
Dan
I will have to check out that thread for sure, used mobil 1 and K&N filter @ 500 mile oil change. Just happen to see this and thought I would ask about it.
Thanks Dan!
No tune in mine, stock 18 Winder, gonna do the 500 mile service. Dan do you recommend Mobil 1 5w/30 for a stock Winder(that’s full synthetic correct?)
Or just stick with the Yamalube?
I run it.....its rated very high in that massive load test....and cheap at walmart.
Just did my first change at 550 miles, lots pics in my build thread and videos of how to get ALL the oil out.
Just be sure to get the normal 5w30 M1.....not high mileage or extended life ect....Lots of pics in that thread of it, walmart has it cheap.
Thanks for the response. No problems in the extreme cold with it??
Has not been colder then minus 25 yet since change.
I would only worry about this if I always was starting my sled in minus 40 all the time.
-25f? Or -25c?
What’s the difference between 0w-30, and 5w-30 with regard to cold weather starting??
Ok, went out and bought the Full Synthetic Mobil 1 5w-30, and the KN-147 K&N Oil Filter. Gonna go with this for the 500 mile oil change.
Wonder why Yamaha recommends semi-synthetic oil instead of full synthetic??
. If you're doing the oil change your self JD, do the belly pan mod like Rocker Dan first. Trust me, the oil change will be a dream. Wish I would've moded mine first. What a mess !!!!
I have not run anything but full synthetic in EVERYTHING I own for maybe 20 yrs now....
Semi synthetic in this monster engine, not for me.
