BA
- Jan 11, 2005
Just greased up the jackshaft and drive axle bearings on my RS Venture, and as I was placing the secondary clutch back on the shaft I noticed between 1/16 and 1/8 of end play when the bolt is torqued.
I didn't notice the end play when I removed the bolt, but I was focused on holding the sheave more than anything.
I did make sure that the two spacers were between the secondary and the bearing in the same orientation as original.
Thanks in advance for your advice.
PS: Bearings needed regreasing big time at 3000 miles!
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
Yes the secondary should float a little on the shaft
apex_man
Yes my 2007 RTX is the same.
