Is this the Starter Solenoid for Vector LTX?
CaptCaper
Northern N.H.
2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
LOCATION
New Hampshire
I'm trying to hook up the Yamaheater starter saver. Rock says to hook it to the starter solenoid but in the fiche I only can find a starter relay.
Is the wire in the 12 oclock position with the white tape on it the wire from the solenoid to the starter?
The starter solenoid & the starter relay are the same thing.
(Most in the industry call the heavy current, low duty cycle relays, solenoids)
Yes, you want the large wire going TO the starter, which in your case is White.
Hope this helps!
Rock :-o
Thanks Rock your support is 1st class.
Where are you guys locating the LED on the sled?
I'm going to put mine to the right of the message display. Be hard to miss if it's on. I have my Yamaheater LED on the other side and that works fine.
I'll put some disconnects to it so when I remove the headlight/windshield for serviceing I'll come off.
