Ryanshimon
- Feb 6, 2020
- Minnesota
- 2010 Nytro XTX
Hi, I'm having an issue finding and parts for a 10 Nytro with the stage 1 MPI SC. Since MPI is no longer around and the parts number on the pulley do not cross im running into a dead end. I had a pulley let loose and am looking for a 28 tooth pulley, torque lock and belt. Anyone have any luck finding these from Gates or Grainger? Part numbers would be awesome, or if you have any extras laying around I would be happy to buy them.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I also need a 3/4” taper lock. For my apex mpi jackshaft. Ill let you know if i find anything.
Ryanshimon
- Feb 6, 2020
- Minnesota
- 2010 Nytro XTX
Might have found the taper lock, rolled the dice and ordered one.
https://www.ebay.com/itm/1108-X-3-4...944673?hash=item4b6e971e61:g:RmEAAOSwlqJdcwct
kinger
- Jan 17, 2005
- Clear Lake, IA
I found it on Grainger. There are two sizes (width) 1.5” and 0.875”. Mine measured exactly 0.875”. Will be here tomorrow.
Ryanshimon
- Feb 6, 2020
- Minnesota
- 2010 Nytro XTX
I found the belt through Grainger also. They stopped carrying Gates belts but I found a replacement from Continental. Part #39GC64. 90 tooth 21mm wide, 8mm pitch
Conti number CTD8m-720-21. Was around $75
kinger
- Jan 17, 2005
- Clear Lake, IA
My taper lock came and it worked flawless. It also said Dodge on it LOL so Ryanshimon you're good to go. Great news on the belt too!
Patcarol
- Feb 17, 2020
- Labrador
- Nytro mtx
Can anyone help me find a mpi stub shaft for a Yamaha nytro for the bottom pulley
Any help can be good
Attakapex1000
- Nov 30, 2018
- 2010 supercharged Nytro
Anyone know where to find pulleys anymore? or should i be looking into scrapping the mpi supercharger kit? cause it impossible to find parts anymore i have tons of other “big” pulleys but nothing the size i need looking for a 27 or 28 tooth
