4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
I sent you a PM, but you may want to check your ground for corrosion.
kuvasz
I tried checking the stator today. I checked the plug off the rectifier but I couldn't get any reading at all. don't I read the ohms off the grey plug from the rectifier? well after I couldn't get any reading I took it for a rip. now it's not only surging it's popping like it's "out of time". I need someone to show my a photo or a wiring diagram on where to check for ohms on the stator plug.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
I posted the diagram in post #14. +pos. in centre white then the -neg to the outer white. Repeat using the other outer white. Both circuits should read the same for a good stator.
scott32
- Jan 12, 2009
Stator?Ground blocks?Coils?tors?Fuel pump?Fuel filter? Have we put this to bed yet?
engineman
- Feb 19, 2013
- Between Hastings & Redwing MN
- 2009 Apex LTX, 2010 Vector LTX GT, 1996 Indy 500 SKS
Also make sure the stator leads are not grounded. I have seen many times where the lead to lead resistance is correct but the leads are also tied to ground. If tied to ground the stator is bad or the wires are shorted somewhere.
Steve
kuvasz
dave marshall from hurricane performance found the problem. I want to thank everyone for their inputs and a "big" thanks to dave. now i'm starting to dial in the pcv map.
Awesome. what was the problem?
That's great! Yeah what was the issue?
