james-30
- Sep 6, 2014
- 2007 Apex Attak GT
Anyone know where I can find a quality secondary side bearing for the jackshaft on a 07 attak gt? Dealer wants $35. Part # 93306-20650-00
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
The dealer is the only place to get that bearing, it is a one way bearing.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
You can get them other places but $35 is a pretty good price and you know you are getting good quality. You can get an entire kit with all the jackshaft bearings and seals from All Balls for a few dollars more but most people on here would advise against it.
http://www.allballsracing.com/14-1050.html
james-30
- Sep 6, 2014
Yea I honestly never cared for all balls. I'm replacing all chain case, cover, speedo bearings with NTN, oem seals.
james-30
- Sep 6, 2014
I found bearing 93306-20650-00 for $27.70 from all me searching I think that's best price I gonna find.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Here is a thread that has lots of good bearing info:
http://www.ty4stroke.com/threads/driveshaft-bearing-numbers.77281/
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
that bearing is so fun to change I would be looking for the most expensive/highest quality one i could find so i didnt have to do it again. just my .02
james-30
- Sep 6, 2014
I bought OEM. Whats so hard about changing it? You have any tips that might help me get it off.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
It' a easy job, remove the complete chain case, make sure you get the bearing in the right direction,
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Search for the step by step directions in the tech section and if the bearing won't come out heat the aluminum housing. Keep all your chain-case parts on the bench in the order that they come off- use zip ties if you have to.
james-30
- Sep 6, 2014
I can't find the step by step how to. Anyone have a link?
Click on the ty tech link in the bar at the top of the screen and it will bring you to the step by step directions on how to do it.
sx7001
- Jun 28, 2003
- Sidewinder
The 11+ apex's are much easier and no chain case removal. I wonder if the new set up could be adapted in to the older sleds?
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I was not aware of that change good to hear.The 11+ apex's are much easier and no chain case removal. I wonder if the new set up could be adapted in to the older sleds?
