Hello Everyone,
I have replaced the jack shaft bearing on my 06 Attack and I'm having problems with getting the chain case assembly completed.
I have tried to re-assemble the brake rotor, but my problem is I do not have enough space for the key that holds the rotor and the spacer.
Does anyone have a measurement on how much jack shaft should be extruded on the secondary clutch side?
Thanks,
Pat (on attack)
