pileit
- Nov 24, 2017
- new brunswick
- 2003 rx1 er
hi,
i need to jack up the front of my sled to replace a couple of bushing on the upper a-arm. i dont have a lift, just a https://www.princessauto.com/en/detail/2-ton-triple-lift-multi-purpose-floor-jack/A-p8369035e can i safely do this? ive never jacked my sled up in the front before, i dont want to damage anything. im thinking there must be a structuraly solid point under there to jack it up from?
If I jack the front end up to change carbides. I use a floor jack with a block of wood under the sled.
You can stay back close to the track which is a solid spot to support. As you probably know don't suspend the sled by the front bumper.
