sledheadgeorge
Anyone try jet coating exaust pipes with this product?
TurboVector
I just had my muffler coated on my Vector to try and cut down on under-seat heat. Next year I'll do the turbo and exhaust pipe.
OTIS RX-1
I had my whole system done at Northeast Coatings in Berlin Ct.
They did the "Y" pipe and the exhaust side of the turbo housing with their ultra high temp coating (good to 2,000F) and the exhaust pipe with the standard 1,300F shiny silver coating.
I haven't run it yet, but everyone that's had it done says it works great and is worth the investment. About $210.00 for the whole thing.
Otis
Otis
sledheadgeorge
I think I'll try the pipes this year. If it holds out well I will do the turbo housing next year. I wrapped the exaust pipes last year but some of those high speed runs eat away at the wrap in a couple of spots. Thanks guys
Colorado Yamaha
- Sep 4, 2005
- Colorado Springs
- 2010 Nytro MTX - MCX
Swain Tech - White Lightning
I coated my entire exhaust system from the motor back and the heat shields. When I shut off the sled, any snow that drops on the pipes will not melt ~ it is that cool. You can even put your hand on it in the shop. Highly recommend. I have a S/C but this should work even better for Turbo applications.
Edit: this is Swain Tech White Lightning coating. All of my 2-s's I use Jet Hot.
OTIS RX-1
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Yup, Fireball Coatings also does a great job of this up here in Canada!!!
summitking
sled
Does anyone do that coating up here in BC? i live in the okanogan and would like to get that done if theres some one local who does it
87gtNOS
- Nov 30, 2005
- Toronto
Re: sled
The real bonus for you is that Fireball Coatings is in Ontario...so you wouldn't have to worry about the border, should you choose to have your stuff done by him!!
summitking said:Does anyone do that coating up here in BC? i live in the okanogan and would like to get that done if theres some one local who does it
BigDog05
How is the heat coating holding up for you guys?
Summitking, you should give Alpine/Powderlites a call where they have there headers done. Last year I had my cpr header done in Edmonton with the 2000F stuff, it fell off. Another buddy had his boondocker header done also, it didn't work. This year I have a Powderlit header, and coating is standing up alot better, will be able to tell by the end of the season. I think the only stuff that works is the Swain coatings like the pics. Only problem for us its in NY.
BigDog05
Colorado Yamaha: I'm getting ready to send my exhaust to NY next week, how did the Swain coating hold up? Thanks
DWHalverson
- May 16, 2006
Does the whole turbo need to be dissasembled to coat the center housing, or can it just be taped off and sprayed? I don't think oven temps reach operating temps.
summitking
sled
I had QC universal coatings do mine in salmon arm bc but i just did the exaust going to the turbo.
Colorado Yamaha
- Sep 4, 2005
- Colorado Springs
It's the best I've seen yet, it's only been one season but running boost, it's doing great. I will be doing my Grizzly pipe the winter .. I won't use anyting else now, even for looks after seeing how WL performs.
