Todd Beenen
Not 400 miles on these , supposed to be new and improved wheel that has the color specs in the wheel, bearing already let go.won’t return my calls, or reply to my text.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Todd has always gotten back to me....maybe he is UP North riding.
Todd Beenen
I’ll try Monday, could be riding.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
He is the best, he stands behind his products, so yes he must be riding!
I needed some parts form him for some that I broke.
He had all in stock and mailed it pronto!
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
The wheels are OK, but they use Chinese bearings. I had one fail and I now use SKF bearings.Not 400 miles on these , supposed to be new and improved wheel that has the color specs in the wheel, bearing already let go.won’t return my calls, or reply to my text.
Todd Beenen
For the price of them you would think they would come with those bearingsThe wheels are OK, but they use Chinese bearings. I had one fail and I now use SKF bearings.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
mine all turned like stop sign shape after 500 miles that run on studs, the middle big wheels on axle that run on studs were semi ok and the outside i lost one as the circlip came out. ive now put the 8" kimpex kawasaki invader wheels which i use to use on all the big wheel kits i did for 25 years, they have never lost rubber or failed and are 40.00 canadian and the BRP/Kimpex 141mm wheels on the inner idlers.... you cant run them on gravel and they last.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
These also work, 141mm and same bearing.
Todd Beenen
Like those with rubber on the outside of wheel.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I also have JT idler wheels but the 2 inside ones are starting to show flat spots from the stud heads so I ended up picking up 2 of the PPD idlers for the inside. They seem to be very well made.Like those with rubber on the outside of wheel.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
I spent 400.00 on all 8 wheels, lost 1 and turne 4 into stop signs. put the cheap BRP or kimpex on and they show absolutly no issues... those ones above look nice too at 141mm
Todd Beenen
It wasn’t the bearing or wheel that failed, once I got the sled in the heated garage , I found the mount loose and the bolt holding the wheel loose.I owe JT an apology, all my fault, just wanted to admit my mistake, carry on.
