kickback
srx900
oswego ny
My sled seems to kickback to much over large rollers. I have rtxse with ohlins rear shocks with high and low speed compression adjusters with rebound adj I also have the 2100nm springs installed with hygear tortions spring spacers. I weight around 280 with gear and I have the star suspension relocate kit with a 136 extention kit. I am running a 144 backcountry the sled is kicking back to fast. I adjusted the rebound to slow it down and adjusted the high speed compression to softer and the low speed compression to harder. Its better but I am wondering if I have too much spring I have the torsion sring set in the softest setting.
Try adjusting your rebound to 3clicks from your softest setting ( usually counter clockwise on a dial type knob ) if it's on the shock shaft like the stock rtx shocks its in the loosening direction, just like a nut on a bolt. Never leave the adjuster in the full soft or full hard position, always at least 3 clicks either way.
