leak down test? compresion test ?
yamman
Grand Tracadie PEI Canada
2010 gt using quarter to half quart per 500 miles sled has gen 11 yamacharger runs very strong no smoke going to do compresion test and leak down test can anyone tell me the specks. or where to find them .
Where do you have your crank case vent going to? Mine had a lot of oil in impeller housing and actually dripped on the floor after siting for a bit. If you do it they way they recommend the vent hose is actually down hill to the impeller housing and must draw oil out of the crank case especially if you are drawing snow dust to the filter causing more draw on the vent. I took mine out of the impeller housing and went up over the delta box and put a 90 elbow in and routed it back and up. Call G-Force and they will probably send you the small K&N filter that the original kit's came with and install it in the vent hose. I don't have a lot of mile's on mine since the change but i think it will solve the problem. I think i will still have some oil residue but should be tolerable. I had no problem before i put the up date in and changed the vent hose. Keep in mind the stock air box always had oil in it even with the vent going up in to the air box and that is normal.
oil consumption 1/4 1/2 quart 300 500 miles
i isnstalled the gen 2 also danny and i discussed the vent issue and smell of fumes on hard wot runs did you notice increased oil consumptionafter gen 2 i purshased the sled with original kit sled pulls hard have it dialed in will be doing radar runs tomorrow weather permitting dalton black green primary dalton 54 44 black pink secondary 3 3 y c weights 4x4 heel 1 1+2 0 rings tip 11,000 rpm
I did notice oil consumption after the up date. I would bet any thing that is where your oil is going. Mine seems to be back to normal after moving the vent tube out of the impeller housing and up. I don't think the oil was being burned but was ending up dripping off the bottom of the sled. You should not be over 10,800 unless you have the ignition module with timing and rev limiter change. Good luck!
Yamman, Did you get to the bottom of your oil consumtion.
