leaking oil very very badly
onlyblue4stroke
ontario
Canada
07 PZFX 03 RX-1
just to day i noticed tht when i went to warm up my phazer fx with 5600 miles on it it started to drip oil, so i brought my do inside and went back outside to the garage at which time it was almost spraying out...... anyone have this problem yet and if so wht was it ????????? thnk you ur reply will be appreciated
or that there isn't two seals on it. Sometimes the old one will stick on the block.
My valve cover has a hole in in from some weird rubbing......could be that...Happened to me at 4100 miles.
k they figured out wht it was it was so clogged with ice tht line were pinched and it came out of the brether tube...... so changed the oil,shimmed the clutches........ but noticed a big problem the frame is BROKEN...... underneath the clutches and tht whole aluminum side cover piece .......... NOT WARRANTIED there is no visual damage from the outside so not sure how it happend but its 1000.00 bones
Do you have a picture of this?Maybe we can figure out what happened.
:o| :drink:
This is getting just nasty!
These machines have to be defrosted before each ride it seems. CRAZY!
